This command has been replaced with the following command: disable l2vpn vpls fdb mac-withdrawal .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Disables the VPLS MAC address withdrawal capability.
Enabled.
When disabled, the switch does not send MAC address withdrawal messages. If a MAC address withdrawal message is received from another VPLS peer, the local VPLS peer processes the message and withdraws the specified MAC addresses from its FDB, regardless of the MAC address withdrawal configuration.
The following command disables MAC address withdrawal:
disable vpls fdb mac-withdrawal
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
